bbender716
Jan 07, 2020Aspirant
Orbi RBR50 on V2.5.0.38 no longer shows attached devices after changing IP range
So I'm trying to assign a static IP for a raspberry pi. I originally assigned it using the IP Reservation panel and assigned, 192.168.1.97, rebooted, and then when I would connect the pi to the network, the network went down. I then read another thread where someone recommended changing the range to 192.168.1.100 - 192.168.1.200 so I changed the IP range to that.
Now the network comes up, but every time I try to load the Attached Device page it hangs, and if I try to change the IP range back to the original range, I get a:
"400 Bad Request
This server does not support the operation requested by your client."
Displayed. Any help would be appreciated!
- SW_Prodigy
v2.5.0.38 was bad/pulled from NG support website. The new attached device regconition feature has since been fixed in the latest firmware version 2.5.1.8.
