thatguy01
Aug 22, 2021Aspirant
Orbi RBR50 password recovery
I am trying to log in to orbilogin.com and do not have the correct credentials. I do not seem to remember the password recovery answers. Is there any way to get in short of doing a factory reset and ...
Aug 22, 2021Guru - Experienced User
Nope.
If you don't know the password recovery questions (or didn't set them up) and don't remember the password, you'd need to factory reset to get back in.
push and hold reset for 7-15 seconds while powered on
thatguy01
Sep 07, 2021Aspirant
Thank you. Does that mean that I have to set up my wifi names and password again? Or, will it remember any settings from before the reset? I appreciate the help!
- plemansSep 07, 2021Guru - Experienced User
Reset clears out all the settings. So simply write down your ssid/password info. that way when you reinstall, you can use the same and devices should auto reconnect.
