packavette
Jan 19, 2021Aspirant
Orbi RBR50 poor video call quality
Hi, I have had the RBR50/RBS50 combination for a few years, and over the past few months have noticed an issue as we are working from home more and making more video calls. When I have both the ro...
Jan 20, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
