johnl4th
Feb 14, 2020Aspirant
Orbi RBR50 port 443 blocked
I have an Orbi RBR50 and when I run stuff on my web server it says 443 and 80 ports are blocked. I configured port forwarding to and from that static ip. It just stopped working...
- Feb 17, 2020
Windows Server Essentials was broken. It was the Anywhere Access website so... it doesn't work well.
No wonder they got rid of it in Server 2019.
CrimpOn
Feb 14, 2020Guru - Experienced User
Maybe more explanation will make the situation clear.
- There is a web server inside the Orbi LAN, with a specific IP address.
Can you share what sort of web server? on what platform? (Windows, Linux, etc.) - On the Orbi Advanced Tab, Advanced Setup, Port Forwarding, ports 80 and 443 are forwarded to the IP of this web server.
- The firewall of the computer the web server is running on has ports 80 and 443 open to the web application.
What is the specific error message?
