Plumbuddle
Nov 09, 2018Star
Orbi RBR50 port forwarding -- can't find tab
I'm trying to install circle premium on my Orbi. It's glitched in part because I haven't got certain ports open. Circle have told me to perform the following operation to start opening the ports: ...
Nov 09, 2018Guru - Experienced User
Try a different browser like IE11, FF or Opera?
- PlumbuddleNov 09, 2018Star
Thank you so much, I have and it works. But having followed the advice on the port opening process I've not been able to apply my changes. I get the error message "The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type". I have no idea how to check these or what I am looking to do once I've found them!!! Is there any advice you could give?
- FURRYe38Nov 09, 2018Guru - Experienced User
If your setting up any Port Forwarding configurations, you need to disable uPnP first. Then PF should work on saving.
That doesn't work for me. I switched uPnP off and applied, then I did the same process. Got this error message: "The specified port(s) are being used by other configurations. Please check your configurations of USB Readyshare, Remote Management, Port forwarding, Port Triggering, UPnP Port Mapping table, RIP, and Internet connection type".
Is there anything else I can do than disable UPnP? Thanks so much
