Yoyo64
May 30, 2021Aspirant
ORBI RBR50 Port Forwarding issues
Have set Port Forwarding on Port 90 to view my CCTV Box which is working. However, the Router appears to close this Port intermittently for no reason. I have ran Port Open Scanner Test and the Port ...
CrimpOn
Jun 02, 2021Guru - Experienced User
As FURRYe38 mentioned, port forwarding only takes place when the target device is accepting connection requests.
Is there a way to verify from the LAN that port 90 on the CCTV box is accepting connections?
It is frustrating that web resources that scan for open ports cannot detect that a router has forwarded a connection request. They can only detect a response from the target device that has passed back through the router. If the port scanner reports 'open' part of the time and 'closed' part of the time, there may be an issue with the CCTV box.
If the port never reports 'open', that would be an indication that there is a router ahead of the Orbi that is not allowing connection attempts to reach the Orbi. Since the original post speaks of seeing the port 'open', this is not likely.
- Yoyo64Jun 03, 2021Aspirant
Thanks for your reply.
I am not sure how to verify port 90 is accepting connections, do I need to Ping this? If so how?
The Port has shown an open connection when the system was working, but for some reason it appears the Port has been closed by itself?? It is or was an intermittent problem but now it seems to be always closed. ( one week and counting)
The CCTV Box was never a problem with my Old Router (Virgin Super Hub 3), however, to get it working I needed to set the IP address to DMZ mode.
Also, the CCTV Box connects to the Orbi Router via an `Ethernet Cable (if this helps).
thanks.
- CrimpOnJun 03, 2021Guru - Experienced User
Yoyo64 wrote:I am not sure how to verify port 90 is accepting connections, do I need to Ping this? If so how?
Can you use the same method that is used remotely, only to it from within the Orbi LAN?
(The problem is that I do not know how you access the CCTV feed remotely. Web browser? Software package?.)
If, for example, access is by opening a web page,such as http://<public IP address>:90
Then try this http://<local IP of CCTV box>:90
In the US, the vast majority of residential customers get dynamic IP addresses from their Internet Service Provider, which means that the ISP can change the IP address at any time without any warning. The way we deal with the uncertainty is to sign up with a Dynamic DNS service (and pay them) so that a specific domain name will always point to the public IP even if it has changed. When I connect to crimpon.myNetgear.com, that gets converted to my current public IP address. Without using DDNS, then I have to check every time, "Has my public IP address been changed?"
Many thanks for your reply.
I only need the CCTV Box for local viewing in my house, the Local IP address is 192.168.1.149:90 (this is programmed into the CCTV box and is a fixed address)
I test this using an Open Port Checker or running an App called "Super Live Plus"which is a dedicated compatible App for my CCTV box.(Mac OSX and Windows are no longer compatible with my CCTV Box, SuperLive Plus on my iPad/iPhone is the only way to view a live feed)
The Public IP address in the UK is the same as the US, it can change periodically. I also have a DDNS account/address but do not use this at the moment until I get my CCTV box to work locally first.
Maybe the only option I have is to connect a VGA Monitor directly to the CCTV Box?Regards.....
