Yoyo64
May 30, 2021Aspirant
ORBI RBR50 Port Forwarding issues
Have set Port Forwarding on Port 90 to view my CCTV Box which is working. However, the Router appears to close this Port intermittently for no reason. I have ran Port Open Scanner Test and the Port ...
Jun 02, 2021Guru - Experienced User
Ports are open only when being used. Be sure the port is being used before testing the port condition.
Yoyo64
Jun 03, 2021Aspirant
As far as I know the Port is being used because it is a Live Stream of my CCTV Cameras.
it was working and then for no reason after about a week it went off line for several days then it came back on all by itself.
There was never a problem with my old Router (Virgin Superhub 3) , however, I did need to set the IP address to DMZ mode.
So the ISP is Virgin Media Broadband (UK) and the Router/Modem is a Virgin Super Hub 3 set to Modem Mode.
Orbi Firmware Version is : V2.7.2.104.
