FastFreddy
May 10, 2018Aspirant
Orbi RBR50 Port Forwarding not working
I just cannot get port forwarding working on the RBR50.
It’s on the default setting of Router and connected to BT with an Openreach modem via PPPOE
All I’m trying to do is make an http pa...
FastFreddy
May 12, 2018Aspirant
No router - just bridged. Its just a modem...
F
DarrenM
May 15, 2018Sr. NETGEAR Moderator
What port are you trying to forward?
DarrenM
- FastFreddyMay 16, 2018Aspirant
I have a Raspberry pi on the network serving a web page, so port 80.
Just want to make it accessable on the wan.
It's really only a test. I actually need to get my VOIP phone working but thats another story...
F
- DarrenMMay 17, 2018Sr. NETGEAR Moderator
Usually port 80 is limited to be accessed from your internal network; the reason being it usually is assigned to the web admin interface.
DarrenM
- FastFreddyMay 17, 2018Aspirant
My orbi's remote management port is 8443.
If I enable that in settings it works!
I should be able to port forward 80 - in fact I'n not able to port forward any ports!
F
