kb0wwp
Sep 18, 2021Aspirant
Orbi RBR50 Port Forwarding randomly stops working
I have had the Orbi RBR50 with one satellite for three years and it has functioned perfectly. In the past few days I have noticed unusual behavior. Connections dropping, and some devices/computers ...
Sep 18, 2021Guru - Experienced User
Is Armor or Circle enabled on the RBR?
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
kb0wwp
ISP Modem is Spectrum E31U2V1 DOCSIS 3.1 eMTA.
Circle is enabled (and always has been). Armor was not previously enabled, but was enabled by default when the Orbi was reset. I have now disabled Armor in case that was the issue.
The power has been turned off and on a few times since the software update. The last software update was probably several weeks ago. Therefore the factory reset and setup from scratch this morning has been performed since last FW update.
