sminer
Jun 23, 2020Aspirant
Orbi RBR50 Problem with ATT Fiber
Hello, I am having an issue with IP passthrough on my Orbi mesh system. I followed the Netgear steps(see below) of setting my Orbi Router system to AT&T, however, my speeds suddenly drop from 900...
Jun 23, 2020Guru - Experienced User
AP mode for the Orbi behind the modem router should work well. No IP Passthru is needed for AP mode.
Be sure to turn OFF all wifi radios on the ISP modem.
sminer
Jul 03, 2020Aspirant
Sorry for the time between replies. As far as I know the firmware on my Orbi's is up to date, however, i am unable to verify since I am unable to log into my Orbi system.
As for question two I have reset everything to factory defaults and run the above setup configuration again. I am getting mediocre speeds and cannot log into the Orbi's via the website or app. I am reluctant to reset everything up, because it is a pain in my rear and am worried it will either not work or will be exactly the same problem.
- FURRYe38Jul 03, 2020Guru - Experienced User
