Joey17
Nov 30, 2020Tutor
Orbi RBR50 Pulsing White and no Network Appearing
A week ago my Orbi mesh network completely went down (an RBR50 with 2 RBS50 satellites). The RBR50 was pulsing white and the network could not be found in any of my devices. I believe the satellietes...
Nov 30, 2020Guru - Experienced User
Can you access the RBRs web page with a wire connected PC pointed to 192.168.1.1 after the reset button press of 15 seconds then release?
If TFTP didn't work, then try the other recovery you linked. If that fails, then your RBR needs to be replaced.
Joey17
Nov 30, 2020Tutor
No, I've tried accessing the the web page at 192.168.1.1 via ethernet many times throughout the process and never been able to reach it. Will try connecting to the serial port and see what I can do.
- FURRYe38Nov 30, 2020Guru - Experienced User
Let us know if that works for you.
- Joey17Dec 02, 2020Tutor
Connecting to the serial ports at least gave me a bit more information about the problem. It looks like there's something corrupted about the OpenWrt image because it runs into an error verifying the checksum:
## Checking Image at 843bffc0 ... Legacy image found Image Name: ARM OpenWrt Linux-3.14.77 Image Type: ARM Linux Kernel Image (lzma compressed) Data Size: 39061504 Bytes = 37.3 MiB Load Address: 40908000 Entry Point: 40908000 Verifying Checksum ... Bad Data CRC rootfs checksum error ## Booting kernel from FIT Image at 84000000 ... Using 'config@1' configuration Trying 'kernel@1' kernel subimage Description: ARM OpenWrt Linux-3.14.77 Type: Kernel Image Compression: gzip compressed Data Start: 0x840000e4 Data Size: 3523429 Bytes = 3.4 MiB Architecture: ARM OS: Linux Load Address: 0x80208000 Entry Point: 0x80208000 Hash algo: crc32 Hash value: 8b1e9c99 Hash algo: sha1 Hash value: d3b5236481fead36da4d4b1da5363d14b5fb553e Verifying Hash Integrity ... crc32 error! Bad hash value for 'hash@1' hash node in 'kernel@1' image node Bad Data HashIs there a way to reinstall OpenWrt? I'm assuming the standard TFTP firware updates don't update OpenWrt but correct me if I'm wrong. Using TFTP to upload a new firmware version doesn't change this error message.
