Bryan57
Jul 30, 2020Aspirant
ORBI RBR50 randomly drops internet or individual devices stop working
I'm running a 2 unit Orbi mesh, hard connected. Orbi preiodically, about one a week or once every 2 weeks just drops internet or stops allowing devices to connect. I have to reboot the primary rout...
jejansso
I used to have similar issues with my RBR50 which seemed to relate some of the automatic firmware updates causing issues with old settings on the router. What I did was ensured that the router was updated to latest firmware and did a reset to it (by pressing the reset button on the back with a pin) and did seemed to remove my random disconnect issues.
Hope that you get your issue sorted out!
