eriklindgren
May 29, 2020Tutor
Orbi RBR50, RBS50 and RSB50Y placement
Netgear webGUI report bad connections between satellites and router. I am trying to understand the optimal physical placement of the products to maximize performance. Since the proucts are quite bulk...
May 29, 2020Guru - Experienced User
Best practice? is what works.
1. they need to be at least 30 ft apart. thats kind of key for the roaming/handoff setup.
2. height does matter a little but what matters more is whats in the walls and whats obstructing the devices. sometimes higher might work as it clears objects in a room or hvac/materials in the walls. In others, lower might work better. I played with placement of mine for months before settling on a set arrangement that worked the best.
again, play with them a bit. I can't tell you whats best other than to try placing them in different areas/heights to see what works best. And one area might have a "best" spot but your signficant other say "i'll hurt you if you put it there".
eriklindgren
Jun 06, 2020Tutor
Can you elaborate a little more on "they need to be at least 30 ft apart." ?
I have thick brick walls, therefore I have bought an additional satellite to enable line of sight between the Orbis (thinking that must be an advantage), but that also resulted in shorter distance then 30 ft, I would estimate 20 ft. I also have a satellite on another floor (open staircase) that also is about 20 ft. Do you think that could be a problem?
