DPierce
Jul 02, 2020Aspirant
Orbi RBR50 RBS50 Firmware Version 2.5.1.32
Last night (July 1, 2020), I updated the router through the app since it found an update. My RBR50 router and two RBS50 satellites updated from 2.5.1.16 to 2.5.1.32 automatically. Problem is, that ...
Jul 02, 2020Guru - Experienced User
You might downgrade the RBR back to v16, factory reset the RBR and RBS then walk thru the setup wizard, add the RBS, then check for the update again.
New FW seems to always appear on the Orbis FW update page first before the manual file downloads appear on the web site.
- CrimpOnJul 02, 2020Guru - Experienced User
DPierce wrote:Last night (July 1, 2020), I updated the router through the app since it found an update. My RBR50 router and two RBS50 satellites updated from 2.5.1.16 to 2.5.1.32 automatically. Problem is, that one of my three RBS50 satellites didn't and is still on version 2.5.1.16.
I don't mind updated it manually, but the new version can't even be found in the support downloads page (or any information about it at all).
FURRYe38 wrote:New FW seems to always appear on the Orbis FW update page first before the manual file downloads appear on the web site.
I just looked in both places and 2.5.1.16 is the latest firmware on the Orbi firmware update web page and on the Netgear support web site.
Perhaps the Orbi "app" has a different method of learning about firmware updates?
- DPierceJul 02, 2020Aspirant
Thank you for the reply. I have a bunch of setting I'd rather not lose till I think it can't be helped. Then I'll have no choice, but I think I'll give it a few weeks to see if the update shows on the support page.
I think your'e right about that. It's so weird that "2.5.1.32" wasn't even showing up while searching comments. I thought companies normally put out a version change notice explaining what the update's meant to address.
Thank you for your reply
DPierce wrote:I think your'e right about that. It's so weird that "2.5.1.32" wasn't even showing up while searching comments. I thought companies normally put out a version change notice explaining what the update's meant to address.
You are correct that many companies release pretty detailed explanations of "what has changed". Alas, Netgear does not.
Just as a friendly tip, I would not rush to update Orbi firmware. If the app says, "New Firmware NOW. Click HERE. HURRY.", I would just take a deep breath and look away. I am pretty much of a "bleeding edge" customer, but I have seen too many complaints about new Orbi firmware wreaking havok that I wait a minimum of 30 days after new firmware comes out before even thinking of updating my Orbi. There's a saying, "If it ain't broke, don't fix it." As long as the Orbi system is performing satisfactorily, new firmware should promise something very specific and important to make installing it a good idea.
