DPierce
Jul 02, 2020Aspirant
Orbi RBR50 RBS50 Firmware Version 2.5.1.32
Last night (July 1, 2020), I updated the router through the app since it found an update. My RBR50 router and two RBS50 satellites updated from 2.5.1.16 to 2.5.1.32 automatically. Problem is, that ...
Jul 02, 2020Guru - Experienced User
You might downgrade the RBR back to v16, factory reset the RBR and RBS then walk thru the setup wizard, add the RBS, then check for the update again.
New FW seems to always appear on the Orbis FW update page first before the manual file downloads appear on the web site.
DPierce
Thank you for the reply. I have a bunch of setting I'd rather not lose till I think it can't be helped. Then I'll have no choice, but I think I'll give it a few weeks to see if the update shows on the support page.
