DPierce
Jul 02, 2020Aspirant
Orbi RBR50 RBS50 Firmware Version 2.5.1.32
Last night (July 1, 2020), I updated the router through the app since it found an update. My RBR50 router and two RBS50 satellites updated from 2.5.1.16 to 2.5.1.32 automatically. Problem is, that ...
CrimpOn
Jul 02, 2020Guru - Experienced User
DPierce wrote:I think your'e right about that. It's so weird that "2.5.1.32" wasn't even showing up while searching comments. I thought companies normally put out a version change notice explaining what the update's meant to address.
You are correct that many companies release pretty detailed explanations of "what has changed". Alas, Netgear does not.
Just as a friendly tip, I would not rush to update Orbi firmware. If the app says, "New Firmware NOW. Click HERE. HURRY.", I would just take a deep breath and look away. I am pretty much of a "bleeding edge" customer, but I have seen too many complaints about new Orbi firmware wreaking havok that I wait a minimum of 30 days after new firmware comes out before even thinking of updating my Orbi. There's a saying, "If it ain't broke, don't fix it." As long as the Orbi system is performing satisfactorily, new firmware should promise something very specific and important to make installing it a good idea.
DPierce
Jul 03, 2020Aspirant
Sound advice, thank you. I really only update hoping the USB would magically able to handle an external drive in the next update. I'm using a second older router on the network just for its ability to share my external drive to group folder use. I have a network printer so I don't need a print server. The USB for printshare is of no use to me personally. I'm actually going to replace my Orbi setup with something else with that ability in the next year. I just don't need a full-blown NAS. Of course I know I could just buy a network external drive such as MyCloud, but I've got so many space external drives already; I hate to buy yet another just for the network feature.
Anyway, thank you for the great reply.
