Jaroslaw's avatar
Aug 13, 2017
Orbi RBR50 rebootnig problem FW V1.12.0.18
First time I must say that I am dissapointed with Netgear product :(
Orbi RBR50 keeps rebootnig at random times, works very unstable - have on both main and satelitte latests FW -
Speed and stability was alway an isseu ever since I bought that Orbi system...
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello skrymir
    How often is the unit rebooting? does it happen when you are trying to do something specific on the net?
    DarrenM
    • Jaroslaw's avatar
      Jaroslaw
      Guide
      How often? Hmm few times a week I would say - I work so I can observe it more during weekends.
    • Jaroslaw's avatar
      Jaroslaw
      Guide
      Sorry was away for a bit. Yes I did factory reset. Rebooting usually happens when I use apple TV playing movies from ITunes or using Infuse (Kodi like) to play the movies from my local NAS. Another situation when I download something from Internet using Internet Download Manager.
      But sometimes Satellite disconnects without any obvious reason…
      • DarrenM's avatar
        DarrenM
        Jaroslaw
        We found a issue with the satellites that will be fixed in the next firmware but do you happen to have any special charters or spaces in your wireless password its a know bug that is causing the satellites some issues?
        DarrenM
  • Anonymous's avatar
    Anonymous
    Factory reset won't help... some of us have done it numerous times.  1.11 and 1.12 are just unstable.
    • Skrymir's avatar
      Skrymir
      Guide
      I'm getting the random reboots as well with 1.12.0.18.
  • DarrenM's avatar
    DarrenM
    Hello Jaroslaw
    Have you tried to factory reset the unit since the upgrade to 1.12.0.18?
    DarrenM
