espressodaily
Dec 17, 2019Aspirant
Orbi RBR50 release external IP
How do I tell the orb to release/renew its external IP? I found article for other netgear routers but nothing for Orbi
Dec 17, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be way to release and renew would be to turn OFF the Orbi RBR for 1 minute. Also I would power OFF the ISP modem/ONT for 1 minute as well. This can sometimes cause the modem to get a new IP address from the ISP.
espressodaily wrote:How do I tell the orb to release/renew its external IP? I found article for other netgear routers but nothing for Orbi
