Ninjahedge
Feb 14, 2023Guide
Orbi RBR50 repeated short disconnects.
Good morning all. I have a weird problem that has only just started, or has only become noticeable recently. This past weekend, when playing a PvP game on my Android device, it would disconn...
Feb 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Be sure to disable the Random MAC feature on the Android device while at home:
- NinjahedgeFeb 14, 2023Guide
Thanks Furry, I read this (your standard/auto reply) on some other posts.
1. I tried AP, it didn't work.
2. I have a CAT5, not a CAT6 on the hard-line connection between Verizon and Orbi
3. I am not sure if I can disable the wireless on the Verizon (on the old one, I had to remove the antennae... this one does not have antennae). I will see what I can do with that.
4. I checked the network traffic in my area and the rating was "good". I did a speed test from the browser and from the Orbi app that uses Ookla, no problems on that end.
5. I have 2 satellites. When I reset, it took them a while to reconnect.
6. I have about 50 switches/outlets/smart devices/APs.
7. I have had no real problem with the satellites. I tried the connection right next to the router and confirmed connection to it.
8. I got a new phone, but the problem is on both the new and old phones and only on the Orbi (not on the Verizon or Wireless Network).
I will get on via web access later and get you the other information (specific firmware, DNS settings, etc).
Thanks!
- FURRYe38Feb 14, 2023Guru - Experienced User
1. I tried AP, it didn't work. Would need to figure out why. AP does work. Configuration is key.
2. I have a CAT5, not a CAT6 on the hard-line connection between Verizon and Orbi. CAT5 is only rated for 100Mpbs. I would get CAT6 ASAP that supports 1000Mpbs which Orbi supports.
3. I am not sure if I can disable the wireless on the Verizon (on the old one, I had to remove the antennae... this one does not have antennae). I will see what I can do with that. Ask the ISP for help on disabling wifi radios on there router.
5. I have 2 satellites. When I reset, it took them a while to reconnect. What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.6. I have about 50 switches/outlets/smart devices/APs.
Be sure to disable the Random MAC address features on these devices while at home.
- NinjahedgeFeb 18, 2023Guide
Furry,
I figured out the problem.
It wasn't the ORBI.
Let me go through the points you made.
1st, I do not think I have a CAT6 on this machine, but I am getting over 30MB/s transfer (200mb/sec), so I am definitely getting more than the base 100.
2nd, the distance between the units is about 20 or so feet for one and 50 for another. I live in an old house with plaster/lath walls and ceilings, so there is some metal mesh interference. The 20ft one is a floor down and the 50ft one is two floors down into the basement.
FINALLY, it was your comment about random IP addresses. They WERENT random. I had assigned them. Here's the thing, I got a new phone and transferred the information to it from my old phone. INCLUDING the set 10.0.0.## IP address. They were both trying to access the same IP. When one would do a query (I guess) it would bump the other for a little bit, then the other would get reconnected.
I changed the IP assignment, restarted things and it appears to be working fine now!
Now if I can only get those dang Leviton switches to work!
Thanks!
