Plaxican
Apr 04, 2022Aspirant
Orbi RBR50 Router and RBS satellites with different firmware
Hello all Hope anyone can help with the issue which my router (RBR50) and 2 satellites RBS50. RBR50 and 1 of the satellite are on the current firmware V2.7.3.22 - but ONE of the satellite is ...
Plaxican
Thanks for the quick response.
I have the satellite plugged into the router (RBR50)
The satellite (older version) have magenta/pink led
INVALID HW ID, USE DEFAULT ORBI as a device instead of a satellite.
Apr 04, 2022Guru - Experienced User
You can cheat. Factory reset the satellite.
Then hardwire a pc/laptop into the satellite.
Its default ip address should be 192.168.1.250
from there you can manually update it and re-sync it to the system.
- PlaxicanApr 04, 2022Aspirant
After reset and connected via ethernet to a laptop
The IP is 169.254.167.216 - it's a self assigned IP?
