Plaxican
Apr 04, 2022Aspirant
Orbi RBR50 Router and RBS satellites with different firmware
Hello all Hope anyone can help with the issue which my router (RBR50) and 2 satellites RBS50. RBR50 and 1 of the satellite are on the current firmware V2.7.3.22 - but ONE of the satellite is ...
Apr 04, 2022Guru - Experienced User
You might try downgrading the RBR back to what the RBS has loaded, if you can get the RBS to sync correctly and log into it's web page, then update FW on the RBS at this point, then re-update the RBR lastly.
- PlaxicanApr 04, 2022Aspirant
How do I know or figure out what firmware is on the Satellite? đ
Thanks for helping
