Plaxican
Apr 04, 2022Aspirant
Orbi RBR50 Router and RBS satellites with different firmware
Hello all Hope anyone can help with the issue which my router (RBR50) and 2 satellites RBS50. RBR50 and 1 of the satellite are on the current firmware V2.7.3.22 - but ONE of the satellite is ...
Apr 04, 2022Guru - Experienced User
You might try downgrading the RBR back to what the RBS has loaded, if you can get the RBS to sync correctly and log into it's web page, then update FW on the RBS at this point, then re-update the RBR lastly.
Plaxican
How do I know or figure out what firmware is on the Satellite? đ
Thanks for helping
- FURRYe38Apr 04, 2022Guru - Experienced User
After factory resetting the RBS and waiting 5 minutes with a wired PC connected to it, can you access 192.168.1.250\debug.htm at all with log in as admin and password in a web browser?
