mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
alokeprasad
Dec 25, 2020Mentor
Its like thay have 3 distinct lineages existing in parallel: 2.5.X, 2.6.X and 2.7.X
You'd think this would result in more complicated tech support.
It is better, in general, to have one tested and tried platform and have that intalled on their user base.
GMoGoody8
Dec 25, 2020Luminary
I 100% Agree. It really is annoying and potentially can get non techie owners into trouble. NGs customer service isn't the greatest so most people com here. I think they break down to this now
2.5.X --> Outside US and people that don't subscribe to armor or parental controls.
2.6.X --> This is the more recent 2.5.X
2.7.X --> US Armor and Parental Control subscribers.
I accidenatally went to the 2.7 some time back and I am hesitant to revert to 2.5.X/2.6.X as I don't use parental controls or armor. I decided to stay even with the annoying App popups at times to "setup/subscribe" to those services.
- alokeprasadDec 25, 2020Mentor
GMoGoody8 wrote:I I think they break down to this now
2.7.X --> US Armor and Parental Control subscribers.That would explain my staying at 2.5.2.4, as I don't use Armor or parental control either.
However, their security page implies that they are applying the fixes to the later versions only. Which is troubling.
- CrimpOnDec 29, 2020Guru - Experienced User
GMoGoody8 wrote:2.5.X --> Outside US and people that don't subscribe to armor or parental controls.
I accidenatally went to the 2.7 some time back and I am hesitant to revert to 2.5.X/2.6.X as I don't use parental controls or armor. I decided to stay even with the annoying App popups at times to "setup/subscribe" to those services.Some observations:
- The Armor "popup overlay" has an almost invisible line in tiny blue text on a blue background offering a choice to "Not remind me any more about Armor." I clicked it, got a message saying "Preference Saved", and the Armor offer no longer pops up. (It may come back, or not. Won't know until it does.)
- This 2.7.2.102 version appears to have no Parental Controls options. At least, I cannot find a menu entry anywhere with that title. Nor has an offer for Parental Controls popped up (yet). Somehow, I got the impression that Netgear was "rolling their own" version of Parental Controls. If they have, I see no sign of it.
p.s. This 2.7.2.102 is running on my "Spare Orbi" which I bought on eBay to experiment with Voxel's Orbi firmware. Which is amazing, but not being in the US, he has decided to stick with the "worldwide" Orbi firmware. In the coming days, I may reset the spare to factory, load the configuration from the primary Orbi, and swap them. Since I never found a spare satellite, I'm reluctant to "take the plunge" until all the details are worked out and I have some time to myself.
- FURRYe38Dec 29, 2020Guru - Experienced User
When you factory reset your Orbi with v102 loaded were you not offered any Circle support after the setup wizard completed? I noticed that Circle isn't present, however i didn't factory reset and setup from scratch and have applied FW updates with out resetting so I don't know if the Circle over lay pop up may already be disabled from prior configuration settings.
I see Armor on the home screen but its disabled...
At least here is Access Controls:
CrimpOn wrote:Some observations:
- aaronkaDec 29, 2020GuideInteresting about Circle being gone in v102. I use the actual gen 1 Circle device and its service is being discontinued on Jan. 1st. I belive this will also affect the NG based Circle Parental controls and this seems to confirm that it is gone.
- MrMRBFeb 03, 2021Tutor
I'm a UK customer but based in Africa. My RBR50 (with 1 satelite) is running FW V2.5.2.4. I don't use parental controls or Armor. Should I upgrade to V2.7.2? How would I go about doing that if the automatic updates don't detect it?
Cheers.
- CrimpOnFeb 03, 2021Guru - Experienced User
MrMRB wrote:I'm a UK customer but based in Africa. My RBR50 (with 1 satelite) is running FW V2.5.2.4. I don't use parental controls or Armor. Should I upgrade to V2.7.2? How would I go about doing that if the automatic updates don't detect it?
The newest firmware for the RBR50/RBS50 (2.7.2.104) no longer has the "U.S. Only" comment.It can be downloaded from here:
https://kb.netgear.com/000062857/RBR50-RBS50-Firmware-Version-2-7-2-104
The decision "to update or not update" is entirely yours.
Thanks. But I'm looking for advice as to why I might or might not want to upgrade.
- FURRYe38Feb 03, 2021Guru - Experienced User
I would try v40 first as it's a known ALL regions version of FW which can be manually downloaded and manually applied if you feel the need to update:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Cheers.
