mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
aaronka
Jan 04, 2021Guide
Still can't my RBS50 to update to the same firmware as the RBR50, I guess I will have to wait until it is available for download. I still don't have a good explanation as to why my RBR50 was forced updated in the first place though.
From the Advanced - Administration - Firmware Update page
On the Attached Devices Page
- FURRYe38Jan 04, 2021Guru - Experienced User
You try a factory reset on the RBS and RBR?
aaronka wrote:Still can't my RBS50 to update to the same firmware as the RBR50, I guess I will have to wait until it is available for download. I still don't have a good explanation as to why my RBR50 was forced updated in the first place though.
- aaronkaJan 04, 2021GuideSince I'm only having cosmetic issues with it I'm not willing to go down that rabbit hole. I would like to know how to prevent future forced updates though.
Hopefully NG will post FW files so you can update the RBS manually.
Good Luck.
