mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
Jan 05, 2021Guru - Experienced User
Hopefully NG will post FW files so you can update the RBS manually.
Good Luck.
AllanSor
Jan 05, 2021Tutor
NG has now posted FW for manual update on the support page !
- alokeprasadJan 05, 2021Mentor
Not yet (Jan 5, 2021 at 8 AM EST) for RBK50v2
https://www.netgear.com/support/product/RBK50v2#download
The firmware may be the same for RBK50 and RBK50v2, but we should not assume that they are.
The hardware is different and it stands to reason that the firmware could be different too.
- FURRYe38Jan 05, 2021Guru - Experienced User
v102 has been posted and is now available for manual download and manual FW update to the Orbi 50 series system:
Bug Fixes:
Fixes the device manager display issue on the Orbi app.
Download Link:.https://kb.netgear.com/000062753/RBR50-RBS50-Firmware-Version-2-7-2-102-for-US-Region-Only
This applies to all 50 series Orbi:
Let us know how it works for you.
Good Luck.
