mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
Feb 02, 2021Guru - Experienced User
Thanks for your recommendation, however when I do manual updates, works just fine.
vajim
Feb 02, 2021Master
FURRYe38 wrote:Thanks for your recommendation, however when I do manual updates, works just fine.
That's nice
the average user is happy for you
the success rate indicates otherwise
- BoilerPlateFeb 02, 2021Apprentice
vajim< User Beware. :smileysad:
