mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
CrimpOn
Feb 02, 2021Guru - Experienced User
MrMRB wrote:I'm a UK customer but based in Africa. My RBR50 (with 1 satelite) is running FW V2.5.2.4. I don't use parental controls or Armor. Should I upgrade to V2.7.2? How would I go about doing that if the automatic updates don't detect it?
The newest firmware for the RBR50/RBS50 (2.7.2.104) no longer has the "U.S. Only" comment.
It can be downloaded from here:
https://kb.netgear.com/000062857/RBR50-RBS50-Firmware-Version-2-7-2-104
The decision "to update or not update" is entirely yours.
Feb 03, 2021Guru - Experienced User
I would not assume that v104 isn't for all regions, this version still follows the v2.7 version line thus may still be considered a continuation fix from the v2.7 line and thus maybe a security fix for what may have been missing in v102 which I is still a US region only version. We should confirm with NG support to see if this still holds true.
The newest firmware for the RBR50/RBS50 (2.7.2.104) no longer has the "U.S. Only" comment.It can be downloaded from here:
