mrfranc
Dec 25, 2020Apprentice
Orbi RBR50 Router Firmware Version V2.7.2.102
A new Router Firmware Version V2.7.2.102 installed automatically during the night. So far so good!
MrMRB
Feb 02, 2021Tutor
I'm a UK customer but based in Africa. My RBR50 (with 1 satelite) is running FW V2.5.2.4. I don't use parental controls or Armor. Should I upgrade to V2.7.2? How would I go about doing that if the automatic updates don't detect it?
Cheers.
Feb 03, 2021Guru - Experienced User
I would try v40 first as it's a known ALL regions version of FW which can be manually downloaded and manually applied if you feel the need to update:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
MrMRB wrote:I'm a UK customer but based in Africa. My RBR50 (with 1 satelite) is running FW V2.5.2.4. I don't use parental controls or Armor. Should I upgrade to V2.7.2? How would I go about doing that if the automatic updates don't detect it?
Cheers.
