Sulu_leo
Aug 18, 2019Aspirant
Orbi RBR50 router slowing internet speed when even wire connected
I have 100 mb/s internet speed and I get same speed from my modem but when I use orbi as wifi router speed usually slows down then I connect my ps4 with ethernet cable to the Orbi router but I still g...
- Aug 20, 2019
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #1...
Sulu_leo
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
What are the wired speeds days later with a wire connected PC?
My Modem Netgear C3700 and all the wireless setting are off but the modem side
The PC which conneted the netgear c3700 modem directly has 100Mbps(my Internet speed limit 100mbps)
So I didn't think i could be my modem but modem is 4 years old modem aswell
Aug 20, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
- Sulu_leoAug 20, 2019Aspirant
FURRYe38 wrote:Modem Combo Units:
Couple of options,
I only did disable the wifi before I thoutgh that would fix the double NAT problem which it didn't but I wasn't sure how to do bridge or what would do to modem, so I just found out how to bridge the modem/router and getting the internet direct from orbi router.
Thank you
