CIBER
Nov 25, 2020Aspirant
Orbi RBR50 router week signal around the house
Hi, I purchased Orbi RBR50 and 1 Satellite to cover an area of 1,500 ft. but noticed that connection will drop often even if I am 10 feet far from the Satellite and some rooms will have a very weak ...
Nov 26, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
CIBER
Dec 02, 2020Aspirant
I did all the changes on the Orbi router and seems to have improve a little bit and haven't got any drops. I run Inssider and tells me that my router and satellite are overlapping, Do I need to connect to the Satellite and change the channel or it is by design to be the router and the satellite on the same 2.4GHz and 5GHz frecuency?
- FURRYe38Dec 02, 2020Guru - Experienced User
What is the distance between the router and satellite(s)?No, there supposed to be over lapped.
- vajimDec 02, 2020Master
Changes?
