DapperDano
Oct 11, 2021Aspirant
Orbi RBR50 router will not start or reset
Hi, I have an Orbi RBR50 that I got in a RBK50 two pack that suddenly stopped working. It had previously been working great for two years and I'm out of warranty. The glow from the top doesn't ...
Oct 11, 2021Guru - Experienced User
If this fails then the RBR needs to be replaced:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Try nmrpflash?
Others have had luck with that when tftp didn't work
https://github.com/jclehner/nmrpflash
DapperDano
Thanks, I"ll try that today
- FURRYe38Oct 11, 2021Guru - Experienced User
đ
- DapperDanoOct 11, 2021Aspirant
When trying the Windows TFTP solution, my computer wouldn't even recognize that it was connected to a network when the router was on and connected. Going to try the unbrick utilty next.
