Michael77-
Apr 05, 2020Follower
Orbi RBR50 (router) with RBS20 (Satellite)
Dear all,
I have currently a Orbi system with the RBR20 and 3 x RBS20, unfortunately the walls are thick concrete with
a lot of iron inside the high rise building. I am now thinking to upgrade my systesm. Is it possible to use the
RBR50 (router) with the RBS20 (satelites) I have already?
My idea would be to have a mix of my existing RBS20 (satelites) with a RBR50 (Router) and an additional RBS50 (satelite)
One other question, is it possible only to by the power adapter separatly? This way I could use the RBR20 in my parents
house back in Europe.
Thanks,
Michael
1 Reply
Yes, though you may see same issues with the building materials with the RBR50 as you do with the RBR20.
