bitb2072
Aug 04, 2018Aspirant
Orbi RBR50 running 2.1.4.16 dropping Wifi Connection to a Blackberry running Android
I have had my Orbi for a while now and it is stable with every device in my home EXCEPT my Blackberry Keyone running Android.I do not have the connectivity issues when connected to other routers and ...
Aug 05, 2018Guru - Experienced User
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- bitb2072Aug 05, 2018Aspirant
I already had the channel turned to 6, 20/40 disabled and the 5.0 netowork disabled. I will try the rest of the setting changes and follow up.
- bitb2072Aug 05, 2018AspirantSo, the only change I made was I disabled the Daisy chain and so far everything seems to be stable. I had already made the other suggested changes before addressing the community.
