DanielDanielDan's avatar
Jun 30, 2019
Orbi RBR50 satellit issues
Hi,
After a reboot of the router, no satelites are to be found. However they appear on the divice list insted of as satellites in the network. Why? Anyone with a solution? I have rested the satellites. It is one inddor and one outdoor satellite....
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
