jung89
Apr 15, 2018Aspirant
Orbi RBR50 Satellite dropping connection
I have been using the Orbi RBK50 for 5 months. All of sudden, the satellite is dropping connection constantly. I have checked the Firware version as suggested by many and it is on the lastest rev: ...
Apr 15, 2018Guru - Experienced User
After you updated to v2.1.3.4, you needed to perform a factory reset on both router and satellite(s) then set them up from scratch. Many other others reported having continued issues after the FW update however doing a reset on everything and set up from scratch resolved there problems. I saw this as well. v2.1.3.4 works well. Ya the factory reset isn't normal however for this one specifc version of FW, it's needed. Please give it a try.
jung89 wrote:I have been using the Orbi RBK50 for 5 months. All of sudden, the satellite is dropping connection constantly. I have checked the Firware version as suggested by many and it is on the lastest rev: 2.1.3.4 I have done factory reset and resync to no avail. Any other suggestions?
