Vickyobee
Sep 03, 2021Aspirant
Orbi RBR50 Satellite dropping connection
Hello every 1 I am having a connection prob with Orbi Satellite..It drops off the connection randomly and then comes back after 5-7 Mts and this is happening several times a day Well all this...
Vickyobee
Hi thanks
It's Penthouse
Distance between RBR and RBS IS ABOUT 20 FT.
Ground floor and First Floor
How ever the prob remains
Even if both are at Any distance apart.
Tried from 5 ft to 40 ft
Also have the same connection drop Prob while using ethernet cable
About downgrading to lowrr VER..
Where do I get the old firmware from..
Much thanks
It's Penthouse
Much thanks
Sep 03, 2021Guru - Experienced User
20 feet is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What ethernet cable are you using? Be sure it's good quality LAN cable. CAT 6 is recommended.
Is the RBS directly connected to the back of the RBR or is there a LAN switch in between the RBR and RBS?
- VickyobeeSep 03, 2021AspirantHi
Yes am Using CAT 6 cable..
With regards to the distance
My place is mostly made of concrete.
When I do initial pairing
The RBS shows BLUE light.. N i take it a few feet before it turns Amber...
And if am using CAT6 cable.. The distance shouldn't matter I guess
Thanks- FURRYe38Sep 05, 2021Guru - Experienced User
Ok, concrete will be problematic for sure.
Does the RBS top ring turn ON when it drops connection?
Possible maybe bad bad cabling in between the RBR and RBS...
