sgualandri
Oct 21, 2018Tutor
Orbi RBR50 Satellite loses internet connection when using WIRED backhaul
I am reposting this with some corrections to the title and to the discussion text.
I've been running a Netgear Orbi RBR50 with 2 RBS50 Satellites for well over a year. This morning we ...
sgualandri
Oct 21, 2018Tutor
After isolating the problem to the RBR50 ethernet ports, I spent some time online with Netgear support. Initial tests confirmed that the RBR50 was not handing out IP addresses to devices connected on the ethernet ports. We then used two different laptops (one Mac, one Windows) to directly connect to the RBR50. Initially we continued to get a local assigned (bad) IP of 168.254.....
We then went to the routers Advanced Settings tab and reviewed the LAN PORT statistics using "Show Statistics". We were looking at the status column for LAN1, LAN2, and LAN3. They were either reporting "1000M/Full" or "Link Down". We then walked the ethernet cable through all LAN ports using both laptops. Each time a correct IP address was granted.
Thinking the case was closed, we ended the call. I then connected all my other ethernet cables back to the RBR50 ethernet ports. Then it stopped working again. Long story short, the ethernet cord from the RBR50 to my gigabit switch was somehow causing all the ethernet ports to fail on the RBR50. When I disconnected that cable, everthing worked fine. My setup is Google Fiber Jack -> Goolge Modem/Router -> RBR50. The RBR50 is in AP bypass mode. For now, I simply connected the ethernet cable on the gigabit switch directly to the Google Router. All my devices are online and working fine. When I get the time, I will try connecting the gigabit switch back to the Orbi RBR50 and see if I still encounter a problem. It may be that power cycling the switch removed the issue but I have not tried it yet. My family is tired of me rebooting the network every 10min.
