Glenvis
Apr 16, 2020Star
Orbi RBR50 satellite not connecting...
I have an Orbi RBR50 with one satellite. The base unit is on the second floor in my office. The satellite is one floor down approximately 6 feet offset in my rec room (wood construction with sheet ...
Retired_Member
Apr 16, 2020Don't use the app and stop worrying about what connects to what
does all devices work?
- GlenvisApr 16, 2020Star
VAJim - You are probably right, quit worrying about the details and get on with life.
To answer your question, yes, everytighing seems to be functioning correctly.
Thanks,
Glenvis
- Retired_MemberApr 16, 2020
Glenvis wrote:VAJim - You are probably right, quit worrying about the details and get on with life.
Thanks,
Glenvis
i'm not trying to be anything but simple and logical. i can tell you from experience, i gave up on chasing digital problems such as these years ago. my motto (for the most part) if it works, i move on. i couldn't tell you what device is connected to my orbi and the sats. as long as it works, i'm fine. even if someone were able to force a device to connect to the orbi or a particular sat, what was gained, really?
that's not to say that if it doesn't work as advertised, it'll drive me nuts.
thanks for being honest
