Glenvis
Apr 16, 2020Star
Orbi RBR50 satellite not connecting...
I have an Orbi RBR50 with one satellite. The base unit is on the second floor in my office. The satellite is one floor down approximately 6 feet offset in my rec room (wood construction with sheet ...
Apr 16, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. You can turn down the power output of the RBR to see if this helps any.
Glenvis wrote:I have an Orbi RBR50 with one satellite. The base unit is on the second floor in my office. The satellite is one floor down approximately 6 feet offset in my rec room (wood construction with sheet rock walls). I purchased this system to be used for my new Samsung QLED television in my rec room - approximately 12 feet from the satellite - same room.
Using the Orbi app on my iPhone and checking the Nework Map, then clicking on the satellite, I just noticed the TV is apparently not connecting to the satellite, but is using the signal from the main unit in my office. How does this happen? Wouldn't the TV connect to the closest source? How do I force the TV to connect to the satellite that is in the same room? Or, for that matter, do I want to?
I just find it unusual that the TV (or the satellite?) is doing this. Maybe this is normal, just thought I'd put it out there and see what the consensus is.
Thanks in advance!
- Retired_MemberApr 16, 2020
no copy paste allowed
- GlenvisApr 16, 2020Star
FURRYe38 - thanks for all the technical info, I'll hang on to this for future reference.
Glenvis
