Glenvis
Apr 15, 2020Star
Orbi RBR50 satellite not connecting...
I have an Orbi RBR50 with one satellite. The base unit is on the second floor in my office. The satellite is one floor down approximately 6 feet offset in my rec room (wood construction with sheet ...
Anonymous
Apr 16, 2020Don't use the app and stop worrying about what connects to what
does all devices work?
Glenvis
Apr 16, 2020Star
VAJim - You are probably right, quit worrying about the details and get on with life.
To answer your question, yes, everytighing seems to be functioning correctly.
Thanks,
Glenvis
- AnonymousApr 16, 2020
Glenvis wrote:VAJim - You are probably right, quit worrying about the details and get on with life.
Thanks,
Glenvis
i'm not trying to be anything but simple and logical. i can tell you from experience, i gave up on chasing digital problems such as these years ago. my motto (for the most part) if it works, i move on. i couldn't tell you what device is connected to my orbi and the sats. as long as it works, i'm fine. even if someone were able to force a device to connect to the orbi or a particular sat, what was gained, really?
that's not to say that if it doesn't work as advertised, it'll drive me nuts.
thanks for being honest
