Tonyreis71
Dec 25, 2018Aspirant
Orbi RBR50 Satellite not connecting to the router
I have been using my Orbi RBR50 router with RBS50 satellites for nearly a month without any issues. I noticed that my satellite were connecting to the router. I've tried rebooting them both with ...
ekhalil
Dec 25, 2018Master
Try connecting the Satellite to the Router with Ethernet cable and see if they will sysnc. If you get the Satellite up please make sure it's also updated to the latest software. Please also make sure Daisy Chain is activated (it seems that backhaul does not work properly in this software without Daisy Chain). After that you can disconnect the cable and try wireless backhaul again.
Good luck.
- Tonyreis71Dec 25, 2018Aspirant
Itried connect by cable but but the sittuation kept the same, the router did not see the satelite.
What you menas about dayse chain, whre I can configure this?
i si possible I communicate with the satelite without the router using my PC? I would like to check the firmware.
- ekhalilDec 25, 2018Master
Unfortunately you can't connect to the satellite except through the router.
You can find the Daisy Chain settings here:
Please note that you need to press the Sync buttons on both router and satellite to make them look for each other? You can also use the "Add Satellite" procedure in the GUI as follows:
Thanks I checked and the configuration is corre t, dayse chain ,
I pressed both side the sync button, but does not worked.
Why when I try to reset the satelie it`s not working? Is it a matter of firmaware?
The satelite seems normal, it is on, the led is green, but not answer any action I have done.
