Tonyreis71
Dec 25, 2018Aspirant
Orbi RBR50 Satellite not connecting to the router
I have been using my Orbi RBR50 router with RBS50 satellites for nearly a month without any issues. I noticed that my satellite were connecting to the router. I've tried rebooting them both with ...
Dec 25, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
The satellite should connect to the base router while in the same room for an initial setup. Once you have it synced there, you should be able to power down the satellite, then go place it at the remote location and it should come back online and connected.
Tonyreis71 wrote:
I have been using my Orbi RBR50 router with RBS50 satellites for nearly a month without any issues. I noticed that my satellite were connecting to the router. I've tried rebooting them both with no success. I also tried performing a reset by pushing a paperclip into the reset in the router and satelite, on the router works perfect( I changed the settings a network name and the password) but the Sayelite I pressed the button for as long as 30 seconds and they did not seem to reset to factory settings. It seems that the Satelite lost the comunication with the router and frezzed. Now I not even see the satelite in the www.orbilogin.com , maybe due the reset done in the router. The version of my router RBR50 firmaware is V2.2.1.210. I've been reading in forums about some issues with firmware, though I don't know if that plays any part. Has anyone else run into this problem? Does anyone have a solution?
I also have tried several times to resync the satellite after reseted the router without sucsess . I tried several times reset the satelite but was unable to get them to do that either. It was almost as if they were stuck in some rebooting phase and would not respond to anything. No matter how many times a power cycled, how long I held in the reset button, the only thing they did was blink a white ring. I don't know what caused the issue, I can only speculate that it has something to do with the router updating to a newer version of firmware and the satellites could no longer communicate properly.Now I can not check the satelite firmaware once it is not appering in the www.orbilogin.com anymore, what can I do?Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
