smilelaugh
Apr 07, 2019Tutor
Orbi RBR50 satellite pulsing white
Bought a set with 2 satellites from Costco in Dec 2017. Suddenly one of the satellites started pulsing white continuously. I’ve tried turning it on/off, pressing sync, and pressing the reset button. A...
CrimpOn
Apr 07, 2019Guru - Experienced User
Well, I passed the "color blindness test", but sometimes I think something is one color and others (wife, mostly) tell me emphatically that I am SO WRONG.
These are the only colors that should appear on the top ring:
Satellite ring LEDs
Solid white. Your Orbi satellite is powering up.
Pulsing magenta. When your Orbi satellite's ring LED pulses magenta for the first time, it means that your satellite is attempting to connect to your Orbi router. If the ring LED pulses magenta for more than one minute, it could be for the following reasons: the satellite lost the connection to the router or the satellite is unable to get an IP address from the router.
Solid magenta. Your Orbi satellite ring is solid magenta for 10 seconds if it is unable to obtain the IP address from the router.
Solid blue. If your Orbi satellite ring is solid blue for 10 seconds, the connection between your Orbi router and satellite is good.
Solid amber. If your Orbi satellite ring is solid amber for 10 seconds, the connection between the router and satellite is fair.
This happens when the satellite is in the same room with the router?
smilelaugh
Apr 07, 2019Tutor
Haha I swear I’m not crazy. I went into the room with the router to do this again and recorded the ring lights. Flashes white for 40 seconds, pulses white for 1.3 minutes, then blinks green for 1s, red for 1s and then orange for less than a second.
Screenshots of my video:
- Green: https://www.dropbox.com/s/e6v4y9t2eetmec0/orbi-green.PNG?dl=0
- Red: https://www.dropbox.com/s/j61o4d2goh4jjmu/orbi-red.PNG?dl=0
- Orange: https://www.dropbox.com/s/o2y24xd62fe5zef/orbi-orange.PNG?dl=0
- CrimpOnApr 07, 2019Guru - Experienced User
I got nothing. Sorry.
