jefferis
Sep 19, 2024Guide
Orbi RBR50 Satellite will not connect
Having trouble with a satellite for this RBR50 First of all, clients cannot connect to the satellite's wifi signal with the same password as the base. I restarted the satellite and it lost ...
Sep 19, 2024Guru - Experienced User
Turn OFF all other working RBS.
Try a 30-30-30 reset on the one non working RBS. Then try to re-add it to the RBR using the RBS add satellite funtion on the RBRs web page.
What FW version is on the RBR and any other RBS?
Was the system updated recently? RBS need to be updated first before the RBR is.
jefferis
Sep 19, 2024Guide
Thanks.... weird, but after saying it failed to sync on setup, it now shows an attached device!
Any idea why the wife password on the satellite would not allow someone to connect? I don't see where to find the satellite's firmware version but here is the base:
| RBR50 | |
| Firmware Version | V2.7.4.24 |
- FURRYe38Sep 19, 2024Guru - Experienced User
Does the RBS get an IP address from the RBR? If it does, you might be able to access it by that IP address, try admin and just password as it may not get the admin pass from the router.
If you can get in, Id update ALL RBS first, then the RBR lastly:
- jefferisSep 19, 2024Guide
Thank you. My Orbi at home auto updates. This is at work and does not. I think mine at home updates in the correct manner. This one seems like it needs a manual update. Will follow instructions.
- FURRYe38Sep 20, 2024Guru - Experienced User
Some units may not receive auto updates and since the AC series of Orbi has gone into EoL, NG has problaby taken these models out of the auto update system so you'll not see any more updates. The one link is last one officially released by NG.
