Halewafa
May 25, 2020Guide
Orbi RBR50 Satellite with Switch Not Working
Hi All, Here's the situation. I have my Orbi router upstairs in my office, then have one of the satellites backhauled downstairs in the basement. I have an ethernet running through the walls from...
- Jun 03, 2020
Alright, after a lot of work I finally found the (easy) solution...
1. From running the ethernet signal test from the satellite to the theater, it was determined that the ethernet cable was only sending signals 5-8, missing 1-4.
2. I recrimped the cable to make sure that wasn't the problem, still only received signals 5-8.
3. Got a new Cat 6 cable to pull through the walls, discovered the problem when pulling out the old cable, something (I assume a mouse) had chewed halfway through the cable....
4. Once the new Cat 6 was in place, plugged it into the satellite and the switch, everything worked perfectly.
5. Happy to report that going Router --> Satellite --> Switch --> Roku/Xbox/etc. works with no issues. The switch I used was a TP-Link (TL-SG105).
Thanks again CrimpOn for your help.
Halewafa
May 25, 2020Guide
Thanks for the reply.
So I have my router wired to my satellite, then my satellite wired to the switch. Anything I plug into the switch isn't receiving an internet connection. I have a few things plugged into the satellite that are working no problem.
I thought the switch would be plug-in-play, but are there any settings I need to change with the orbi? I did a reboot after plugging in the switch. No issues with the ethernet cables either, tested all of them.
CrimpOn
May 25, 2020Guru - Experienced User
What happens when the switch is removed? i.e. the XBox or the Roku is plugged directly into the cable leading to the satellite?
I am constantly annoyed that Netgear saved 10 cents by leaving off the LED's on the ethernet jacks. Fortunately, the TL-105 has LED's on each port. Do they light up when devices are plugged in?
Does the Orbi "Attached Device" web page show the XBox and Roku as connected? I don't have a Roku, so I am not aware of how the network is configured to change from WiFi connection to ethernet connection.
Do you have Access Control enabled? The Roku ethernet adapter will have a different MAC address than the Roku WiFi adapter.
- HalewafaMay 25, 2020GuideThe Xbox and Roku connect no problem if plugged directly into the ethernet cable coming off the satellite.
All lights are green (showing a 1000 connection, would be yellow if 100/10).
Neither show up as connected devices when plugged into the switch. I don't see the switch as a connected device either, but not sure if I should.
I do not have access control on.- CrimpOnMay 25, 2020Guru - Experienced User
I do not have access control on.An unmanaged switch will not ask for an IP address, so not "seeing" the switch is normal. I wonder if the Roku or XBox communicate when not connected to a TV? Would be interesting to connect the switch directly to the satellite with a patch cable, connect the Roku to the switch and see if it "appears" when in the same room. Do you have any other devices with ethernet jacks, such as laptops?
I am stuck. If all three ports on the switch have correct LED's (satellite, Roku, XBox), then it should work. Does the traffic LED flicker?
So... I may have figured out the issue. Just ran an RJ45 signal test on the cable going from the satellite to the theater, and the sequence wasn't going 1-8, looks like it was just doing 4-8, so theres an issue with the cable. Looks like I'll have to buy a crimping tool to fix it and try again. I'll report back if thats what the issue was!
