rick9004
Oct 09, 2023Follower
Orbi RBR50 Satellite
Have had my Orbi unit RBR50 for at least two years. Distance between base and satellite is normally about 50 ft. Base can get 300 mbps satellite around 175 ish. Now the most the satellite can ge...
Oct 09, 2023Guru - Experienced User
What firmware is on the satellite and the router?
Did you test wired speed on the satellites? that's the best way to check if the backhaul is causing the slowdown or if its the front haul.
What device are you testing with?
