rick9004
Oct 09, 2023Follower
Orbi RBR50 Satellite
Have had my Orbi unit RBR50 for at least two years. Distance between base and satellite is normally about 50 ft. Base can get 300 mbps satellite around 175 ish. Now the most the satellite can ge...
KevinLiT
Oct 11, 2023NETGEAR Moderator
Hello rick9004 ,
Welcome to the NETGEAR Community!
Please ensure that your Orbi mesh system is on the latest firmware release version 2.7.5.4 then factory reset your satellite.
The RBR50 is compatible with the following satellites:
- RBS10
- RBS20
- RBW30
- RBS40
- RBS40V
- RBS50
- RBS50Y
(Please note the devices attached to the satellite will have a slower network connection than the devices attached to the router if an older satellite is used.)
If you are not on the latest firmware release please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#download
Please visit the link below for additional information on Orbi router and satellite compatibility:
Which Orbi routers and satellites are compatible? - NETGEAR Support
Best,
Kevin
Community Team
