darrenp99
Sep 08, 2020Tutor
Orbi RBR50 Satellitte compatability.
I have an Orbi RBR50 currently setup with 2 x RBS50 satellite, I am looking to add an additonal satellite but i'm having trouble getting hold of another RBS50. Does anyone know if any of the other m...
- Sep 09, 2020
Thanks for all you suggestions, I found an old WN3000 extender, i now connnect that , configured as an AP & works greta for what I need.
Mstrbig
Sep 08, 2020Master
darrenp99 wrote:I have an Orbi RBR50 currently setup with 2 x RBS50 satellite, I am looking to add an additonal satellite but i'm having trouble getting hold of another RBS50.
Does anyone know if any of the other models are compatible, maybe the RBS50 v2 ?
Any info would be much appricated.
Thanks
New RBS50 satellites are available on Netgear's website https://www.netgear.com/orbi/rbs50.aspx.
There are also many used ones available on many sites. You can choose an pretty much an AC line of Orbi. But the RBS is more powerful than most of the other AC systems.
Currently Netgear has the RBS40V tri-band satellite for $99.00. That is a great price. And the fact that it is a great sounding speaker with Alexa, is a plus.
- darrenp99Sep 08, 2020Tutor
I'm in the UK
Thanks
