tgenty
Jun 01, 2020Star
Orbi RBR50 seems stuck in boot loop
Hi, After my orbi performance dropped, I restarted the router hopping it will fix it. However it doesnt fully restart now. The power led is solid green and the ring is solid white for like 20 sec...
brichter1978
Jan 26, 2021Tutor
Well I fixed mine after 10 hours or so.
I ended up booting unit and pressing space from console to stop boot. Manually set IP to 192.168.1.250.
Had ethernet cable with laptop IP at 192.168.1.5 plugged in direct.
Ran this command on laptop and noticed any time I had this command on the router would be pingable. Chnage both -t ans -T to 90000 to give me more time as pingable.
nmrpflash -v -i net19 -f c:\NG\firmware.img -t 10000 -T 10000 -A 192.168.1.5 -a 192.168.1.250
While router was pingable I ran the TFTP and flashed latest RBS40 FW.
Used TFTPd64, also worked with TFTP2.
Then noticed to error below as mentioned in post on link below. Used manual commands and that allowed a good flash. Reboot took FOREVER, but you could see all the action happening on the console. Plugged into my router and within 2-3 minutes it was in the web GUI. No reprogramming or syncing.
HW ID on board:
HW ID on image: 29765515+0+4096+512+2x2+2x2+2x2
Firmware Image HW ID do not match Board HW ID
Board HW ID mismatch,it is forbidden to be written to flash!!
After this I did a set on Mac and then did a Saveenv to memory.
Here is link that was broken posted by other. This link helped me resolve.
https://community.netgear.com/t5/Orbi/Is-my-13-month-old-RBR50-bricked/m-p/2009904
SOLVED RBS40
akinuslu
Apr 06, 2021Aspirant
Came here and created account just to say thank you! Reset button would just not work to upload the firmare that was botched by the automatic update process. But, serial port trick, following your instructions, unbricked the satelite and saved hundreds of dollars in the process.
Some minor details: While I was able to successfully login using serial port, I couldn't figure how to assign a static IP and tftp server would not start without it. Luckily a quick reboot and interrupting boot process, enabled IP address assignment somehow and TFTP server started like a charm and then followed your steps for HW and Model id configuration, save state was not needed in either case.
Thank you again.
This is the last netgear product I'll purchase.
