tgenty
Jun 01, 2020Star
Orbi RBR50 seems stuck in boot loop
Hi, After my orbi performance dropped, I restarted the router hopping it will fix it. However it doesnt fully restart now. The power led is solid green and the ring is solid white for like 20 sec...
tgenty
Jul 22, 2020Star
Well I can't just give up on it yet.
So I've opened the router, found the serial pin on the motherboard and bought a USB-serial cable. Now I can access to the bootloader console but I lack knowledge on this.
I managed to confirmed that firmware upload with tftp works well. However everytime it boots, it ends up with a "data abord" followed by a reset.
Here are the logs of the tftp upload, firmware V2.5.1.32 (I've removed most of the dot while receiving the firmware for clarity)
Format: Log Type - Time(microsec) - Message - Optional Info Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.1-00096 S - IMAGE_VARIANT_STRING=DAAAANAZA S - OEM_IMAGE_VERSION_STRING=CRM S - Boot Config, 0x00000023 S - Core 0 Frequency, 0 MHz B - 261 - PBL, Start B - 1339 - bootable_media_detect_entry, Start B - 129185 - bootable_media_detect_success, Start B - 129199 - elf_loader_entry, Start B - 131586 - auth_hash_seg_entry, Start B - 133734 - auth_hash_seg_exit, Start B - 169767 - elf_segs_hash_verify_entry, Start B - 283099 - PBL, End B - 283124 - SBL1, Start B - 371628 - pm_device_init, Start D - 6 - pm_device_init, Delta B - 373192 - boot_flash_init, Start D - 593 - boot_flash_init, Delta B - 380023 - boot_config_data_table_init, Start D - 74730 - boot_config_data_table_init, Delta - (419 Bytes) B - 460626 - clock_init, Start D - 7523 - clock_init, Delta B - 471575 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:0,Subtype:1 B - 475057 - sbl1_ddr_set_params, Start B - 480042 - cpr_init, Start D - 2 - cpr_init, Delta B - 484532 - Pre_DDR_clock_init, Start D - 5 - Pre_DDR_clock_init, Delta D - 13144 - sbl1_ddr_set_params, Delta B - 497800 - pm_driver_init, Start D - 2 - pm_driver_init, Delta B - 568859 - sbl1_wait_for_ddr_training, Start D - 28 - sbl1_wait_for_ddr_training, Delta B - 585341 - Image Load, Start D - 785135 - QSEE Image Loaded, Delta - (262104 Bytes) B - 1370979 - Image Load, Start D - 888 - SEC Image Loaded, Delta - (0 Bytes) B - 1380825 - Image Load, Start D - 1185462 - APPSBL Image Loaded, Delta - (413427 Bytes) B - 2566718 - QSEE Execution, Start D - 58 - QSEE Execution, Delta B - 2572986 - SBL1, End D - 2291853 - SBL1, Delta S - Flash Throughput, 342 KB/s (675950 Bytes, 1976018 us) S - DDR Frequency, 672 MHz U-Boot 2012.07 [Barrier Breaker unknown,unknown] (Jul 29 2016 - 22:37:42) U-boot dni1 V1.1 for DNI HW ID: 29765352; NOR flash 32MB; EMMC flash 4000MB; RAM 512MB smem ram ptable found: ver: 1 len: 3 DRAM: 512 MiB machid : 0x8010001 NAND: Nand Flash error. Status = 64 ONFI Read id cmd failed ONFI probe failed SF NAND unsupported id:ff:ff:ff:ffSF: Unsupported manufacturer ff ipq_spi: SPI Flash not found (bus/cs/speed/mode) = (0/0/48000000/0) 0 MiB MMC: qca_mmc: 0 PCI0 Link Intialized In: serial Out: serial Err: serial machid: 8010001 flash_type: 1 Net: MAC0 addr:b0:b9:8a:61:af:26 PHY ID1: 0x4d PHY ID2: 0xd0b1 ipq40xx_ess_sw_init done eth0 Hit any key to stop autoboot: 0 (IPQ40xx) # fw_recovery eth0 PHY0 Down Speed :10 Half duplex eth0 PHY1 up Speed :100 Full duplex eth0 PHY2 Down Speed :10 Half duplex eth0 PHY3 Down Speed :10 Half duplex eth0 PHY4 Down Speed :10 Half duplex The Router is in TFTP Server Firmware Recovery mode NOW! Listening on Port : 69, IP Address: 192.168.1.1 ... Rcv: ................................................................. ................................................................. ...................................................... 32 MB reveived .............................................................. Done! Bytes transferred = 43518081 (2980881 hex) mmc_read will run command: mmc read 0x871cfd78 0x2a22 0x100 MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK HW ID on board: 29765352+0+4000+512+2x2+2x2+4x4 HW ID on image: 29765352+0+4000+512+2x2+2x2+4x4 Firmware Image HW ID matched Board HW ID mmc_read will run command: mmc read 0x871cfd90 0x2a22 0x100 MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK MODEL ID on board: RBR50 MODEL ID on image: RBR50 Firmware Image MODEL ID matched Board model ID mmc_read will run command: mmc read 0x871cfd90 0x2a22 0x100 MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK MODEL ID on board: RBR50 MODEL ID on image: RBR50 Firmware Image MODEL ID matched Board model ID mmc erase 0x4622 0x14c05 MMC erase: dev # 0, block # 17954, count 84997 ... 84997 blocks erase: OK Alive-timer 57 NmrpAliveTimerBase 15 Copy image to Flash... mmc write 0x84000080 0x4622 0x14c05 MMC write: dev # 0, block # 17954, count 84997 ... 84997 blocks write: OK boot_partition_set 1 mmc_read will run command: mmc read 0x871cfb50 0x2a22 0x100 MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK Burn BOOT PARTITION DATA (= 110101) into ART block mmc_read will run command: mmc read 0x871cfb50 0x2a22 0x100 MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK mmc_sect_erase will run command: mmc erase 0x2a22 0x100 MMC erase: dev # 0, block # 10786, count 256 ... 256 blocks erase: OK mmc_write will run command: mmc write 0x871cfb50 0x2a22 0x100 MMC write: dev # 0, block # 10786, count 256 ... 256 blocks write: OK Done. Alive-timer 22 Done Rebooting... resetting ... Valid chip addresses: 27 48
and the log of the restart (I've removed lots of MMC read log lines for clarity)
Format: Log Type - Time(microsec) - Message - Optional Info Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.1-00096 S - IMAGE_VARIANT_STRING=DAAAANAZA S - OEM_IMAGE_VERSION_STRING=CRM S - Boot Config, 0x00000023 S - Core 0 Frequency, 0 MHz B - 261 - PBL, Start B - 1339 - bootable_media_detect_entry, Start B - 17387 - bootable_media_detect_success, Start B - 17401 - elf_loader_entry, Start B - 19819 - auth_hash_seg_entry, Start B - 21967 - auth_hash_seg_exit, Start B - 56125 - elf_segs_hash_verify_entry, Start B - 169316 - PBL, End B - 169341 - SBL1, Start B - 257848 - pm_device_init, Start D - 6 - pm_device_init, Delta B - 259418 - boot_flash_init, Start D - 594 - boot_flash_init, Delta B - 266256 - boot_config_data_table_init, Start D - 73578 - boot_config_data_table_init, Delta - (419 Bytes) B - 345709 - clock_init, Start D - 7518 - clock_init, Delta B - 356654 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:0,Subtype:1 B - 360134 - sbl1_ddr_set_params, Start B - 365119 - cpr_init, Start D - 2 - cpr_init, Delta B - 369609 - Pre_DDR_clock_init, Start D - 5 - Pre_DDR_clock_init, Delta D - 13143 - sbl1_ddr_set_params, Delta B - 382875 - pm_driver_init, Start D - 2 - pm_driver_init, Delta B - 453700 - sbl1_wait_for_ddr_training, Start D - 28 - sbl1_wait_for_ddr_training, Delta B - 469956 - Image Load, Start D - 785174 - QSEE Image Loaded, Delta - (262104 Bytes) B - 1255632 - Image Load, Start D - 886 - SEC Image Loaded, Delta - (0 Bytes) B - 1265457 - Image Load, Start D - 1185486 - APPSBL Image Loaded, Delta - (413427 Bytes) B - 2451373 - QSEE Execution, Start D - 58 - QSEE Execution, Delta B - 2457640 - SBL1, End D - 2290290 - SBL1, Delta S - Flash Throughput, 342 KB/s (675950 Bytes, 1976099 us) S - DDR Frequency, 672 MHz U-Boot 2012.07 [Barrier Breaker unknown,unknown] (Jul 29 2016 - 22:37:42) U-boot dni1 V1.1 for DNI HW ID: 29765352; NOR flash 32MB; EMMC flash 4000MB; RAM 512MB smem ram ptable found: ver: 1 len: 3 DRAM: 512 MiB machid : 0x8010001 NAND: Nand Flash error. Status = 64 ONFI Read id cmd failed ONFI probe failed SF NAND unsupported id:ff:ff:ff:ffSF: Unsupported manufacturer ff ipq_spi: SPI Flash not found (bus/cs/speed/mode) = (0/0/48000000/0) 0 MiB MMC: qca_mmc: 0 PCI0 Link Intialized In: serial Out: serial Err: serial machid: 8010001 flash_type: 1 Net: MAC0 addr:b0:b9:8a:61:af:26 PHY ID1: 0x4d PHY ID2: 0xd0b1 ipq40xx_ess_sw_init done eth0 Hit any key to stop autoboot: 0 Valid chip addresses: 27 48 eth0 PHY0 Down Speed :10 Half duplex eth0 PHY1 up Speed :100 Full duplex eth0 PHY2 Down Speed :10 Half duplex eth0 PHY3 Down Speed :10 Half duplex eth0 PHY4 Down Speed :10 Half duplex Client starts...[Listening] for ADVERTISE...TTT Retry count exceeded; boot the image as usual nmrp server is stopped or failed ! Read BootPart from BOARD DATA... mmc_read will run command: mmc read 0x871cfca8 0x2a22 0x100 MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK boot partition : 1 BootPart = 1 Loading DNI firmware for checking... MMC read: dev # 0, block # 17954, count 256 ... 256 blocks read: OK MMC read: dev # 0, block # 18210, count 256 ... 256 blocks read: OK MMC read: dev # 0, block # 18466, count 256 ... 256 blocks read: OK ( ... ) MMC read: dev # 0, block # 102690, count 256 ... 256 blocks read: OK MMC read: dev # 0, block # 102946, count 256 ... 256 blocks read: OK MMC read: dev # 0, block # 17954, count 1 ... 1 blocks read: OK ** rootfs address : 0x843bffc0 ** ## Checking Image at 84000000 ... FIT image found FIT description: ARM OpenWrt FIT (Flattened Image Tree) Image 0 (kernel@1) Description: ARM OpenWrt Linux-3.14.77 Type: Kernel Image Compression: gzip compressed Data Start: 0x840000e4 Data Size: 3524167 Bytes = 3.4 MiB Architecture: ARM OS: Linux Load Address: 0x80208000 Entry Point: 0x80208000 Hash algo: crc32 Hash value: 4b698f35 Hash algo: sha1 Hash value: 439cf7c76bf93d7dd525f87978dbfb0a718c7bf7 Image 1 (fdt@1) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x8435c86c Data Size: 39067 Bytes = 38.2 KiB Architecture: ARM Hash algo: crc32 Hash value: 2fbe7ae7 Hash algo: sha1 Hash value: 10a7fad2926d324e8b06b192c3531c391f78a6ed Image 2 (fdt@2) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x84366214 Data Size: 38617 Bytes = 37.7 KiB Architecture: ARM Hash algo: crc32 Hash value: c0098bb9 Hash algo: sha1 Hash value: baf8b2904ec24c626934dabf5d6815eadedadc29 Image 3 (fdt@3) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x8436f9fc Data Size: 42101 Bytes = 41.1 KiB Architecture: ARM Hash algo: crc32 Hash value: 0109faf0 Hash algo: sha1 Hash value: 34ee6bdafd6315d361d6aa99b5ad45a9944b32dd Image 4 (fdt@4) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x84379f80 Data Size: 34248 Bytes = 33.4 KiB Architecture: ARM Hash algo: crc32 Hash value: 0fa6ee98 Hash algo: sha1 Hash value: dcec33a744cfed6a21c9a9be313791f98b1081ff Image 5 (fdt@5) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x84382654 Data Size: 34407 Bytes = 33.6 KiB Architecture: ARM Hash algo: crc32 Hash value: 96f6beb1 Hash algo: sha1 Hash value: 3a938e8901b816f4fa7d73aacbc3e2b54422c5d0 Image 6 (fdt@6) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x8438adc8 Data Size: 34547 Bytes = 33.7 KiB Architecture: ARM Hash algo: crc32 Hash value: ce835bd9 Hash algo: sha1 Hash value: f48535f83fe16c4d3471b18ddab6dfa5d1a633e7 Image 7 (fdt@7) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x843935c8 Data Size: 38588 Bytes = 37.7 KiB Architecture: ARM Hash algo: crc32 Hash value: bb010bc8 Hash algo: sha1 Hash value: a52a0530438afae1fe5fed13cb380503d0ee576b Image 8 (fdt@8) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x8439cd90 Data Size: 38467 Bytes = 37.6 KiB Architecture: ARM Hash algo: crc32 Hash value: 311234ec Hash algo: sha1 Hash value: c7be34f25ccb51f0d0eaa6985af77d30b872eaef Image 9 (fdt@9) Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x843a64e0 Data Size: 38165 Bytes = 37.3 KiB Architecture: ARM Hash algo: crc32 Hash value: f91b53ee Hash algo: sha1 Hash value: 7f783a91e42dc651bb82f01479f5207640db0d53 Default Configuration: 'config@1' Configuration 0 (config@1) Description: OpenWrt Kernel: kernel@1 FDT: fdt@1 Configuration 1 (config@2) Description: OpenWrt Kernel: kernel@1 FDT: fdt@2 Configuration 2 (config@3) Description: OpenWrt Kernel: kernel@1 FDT: fdt@3 Configuration 3 (config@4) Description: OpenWrt Kernel: kernel@1 FDT: fdt@4 Configuration 4 (config@5) Description: OpenWrt Kernel: kernel@1 FDT: fdt@5 Configuration 5 (config@6) Description: OpenWrt Kernel: kernel@1 FDT: fdt@6 Configuration 6 (config@7) Description: OpenWrt Kernel: kernel@1 FDT: fdt@7 Configuration 7 (config@8) Description: OpenWrt Kernel: kernel@1 FDT: fdt@8 Configuration 8 (config@9) Description: OpenWrt Kernel: kernel@1 FDT: fdt@9 ## Checking hash(es) for FIT Image at 84000000 ... Hash(es) for Image 0 (kernel@1): crc32+ sha1+ Hash(es) for Image 1 (fdt@1): crc32+ sha1+ Hash(es) for Image 2 (fdt@2): crc32+ sha1+ Hash(es) for Image 3 (fdt@3): crc32+ sha1+ Hash(es) for Image 4 (fdt@4): crc32+ sha1+ Hash(es) for Image 5 (fdt@5): crc32+ sha1+ Hash(es) for Image 6 (fdt@6): crc32+ sha1+ Hash(es) for Image 7 (fdt@7): crc32+ sha1+ Hash(es) for Image 8 (fdt@8): crc32+ sha1+ Hash(es) for Image 9 (fdt@9): crc32+ sha1+ ## Checking Image at 843bffc0 ... Legacy image found Image Name: ARM OpenWrt Linux-3.14.77 Image Type: ARM Linux Kernel Image (lzma compressed) Data Size: 39585792 Bytes = 37.8 MiB Load Address: 40908000 Entry Point: 40908000 Verifying Checksum ... OK mmc_read will run command: mmc read 0x871cfca8 0x2a22 0x100 MMC read: dev # 0, block # 10786, count 256 ... 256 blocks read: OK boot partition : 1 MMC read: dev # 0, block # 17954, count 7680 ... 7680 blocks read: OK data abort pc : [<87303568>] lr : [<87304250>] sp : 871efd60 ip : 871f0ad3 fp : 87303557 r10: 00000000 r9 : 00000002 r8 : 871eff60 r7 : 871f0ab8 r6 : 87360cec r5 : 871f0ab8 r4 : 8735e6a4 r3 : ffffffff r2 : 00000158 r1 : 00000000 r0 : 87360cec Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... Valid chip addresses: 27 68
Here is the printenv command:
(IPQ40xx) # printenv baudrate=115200 bootcmd=reset_i2c; mii write 0x0 0x0 0x0800; sleep 1; nmrp; bootdni; bootm 0x84000000 bootdelay=2 delenv=mmc erase 0x1622 0x200 ethact=eth0 flash_type=1 ipaddr=192.168.1.1 loadaddr=0x84000000 machid=8010001 serverip=192.168.1.10 stderr=serial stdin=serial stdout=serial Environment size: 313/262140 bytes
I executed the bootcmd manually and I've confirmed that the "data abord" is issued by the "bootm 0x84000000".
Any help would be appreciated.
Rufus1010
Jan 17, 2022Aspirant
Hello, how did you get connected to the router via the terminal and the USB / pins ??
via windows ?? or MAC ??
as i have the same problem and bought the serial to USB but cannot get any contact via TeraTerm a windows terminal program i installed.
any help is much appriciated here.
- pbarhamJan 17, 2022Apprentice
Rufus1010 wrote:Hello, how did you get connected to the router via the terminal and the USB / pins ??
I was using a Macbook Air
It was a long time ago now, but I think I followed the instructions on this page: https://pbxbook.com/other/mac-tty.html
For the physical serial port connection I used this https://www.snbforums.com/attachments/orbi-serial-port-pdf.23898/
If you're not seeing any console output then I'd recommend double checking which header pins on the motherboard you connected the serial line to. The instructions are very easy to get wrong because there are some other pins close by and the orientation of the motherboard is unclear. I got mine back to front the first time I tried this!
- elzilchoMay 14, 2022Aspirant
do you have a list of commands or instructions on how to do this on windows 10? I have an orbi rbr50 that just has a white solid light and will not do anything. I bought the serial to usb adapter and have a terminal open just dont know what to do next.
- iScreamMay 14, 2022AspirantI gave up. I threw the damn thing to the trash and switched to Linksys. Never using another Netgear device again.
i bought a new orbi. Just wanted to learn how to do something new and see what could be done.
